| Oracle Internet Directory Administrator's Guide 10g (10.1.4.0.1) Part Number B15991-01 |
This appendix describes the format (syntax) of any access control item (ACI). It contains these topics:
The access control directive defined by the user attribute orclACI has the following schema:
OrclACI: { object_identifier NAME 'orclACI' DESC 'Stores an inheritable ACI' EQUALITY accessDirectiveMatch SYNTAX 'accessDirectiveDescription' USAGE 'directoryOperation'}
accessDirectiveDescription has the following BNF:
<accessDirectiveDescription>
::= access to <object> [by <subject> ( <accessList> )]+
<object> ::= [attr <EQ-OR-NEQ> ( * | (<attrList>) ) | entry] [filter=(<ldapFilter>)] [DenyGroupOverride] [AppendToAll]
<subject> ::= <entity> [<BindMode>] [Added_object_constraint=(<ldapFilter>)]
<entity> ::= * | self | dn="<regex>" | dnAttr=(<dn_attribute>) | group="<dn>" | guidattr=(<guid_attribute>) | groupattr=(<group_attribute>) | [SuperUser]
BindMode=(LDAP_authentication_choice)|LDAP_security_choice)
LDAP_authentication_choice::= proxy | simple | MD5Digest | PKCS12
LDAP_security_choice::= SSLNoAuth | SSLOneWay | SASL
<accessList> ::= <access> | <access>, <accessList>
<access> ::= none | compare | search | browse | proxy | read | selfwrite | write | add | delete | nocompare | nosearch | nobrowse | noproxy |noread | noselfwrite | nowrite | noadd | nodelete
<attrList> ::= <attribute name> | <attribute name>,<attrList>
<EQ-OR-NEQ> ::= = | !=
<regex> ::= <dn> | *,<dn_of_any_subtree_root>
Note: The regular expression defined earlier is not meant to match any arbitrary expression. The syntax only allows expressions where the wild card is followed by a comma and a valid DN. The latter DN denoted by <dn_of_any_subtree_root> is intended to specify the root of some subtree. |
The entry level access control directive defined by the user attribute orclEntryLevelACI has the following schema:
"orclEntryLevelACI": { object_identifier NAME 'orclEntryLevelACI' DESC 'Stores entry level ACL Directive' EQUALITY accessDirectiveMatch SYNTAX 'orclEntryLevelACIDescription' USAGE 'directoryOperation' }
<orclEntryLevelACIDescription> ::= access to <object> [by <subject> ( <accessList> )]+
